device profiling on WLC 9800 running IOS-XE
Alex-Pr
Hey everyone,
Is there a way to update the OUI database in the WLC running IOS-XE.  I think there was a way with AirOS, but I don't see it in IOS-XE
What I want to do us upload the updated OUI database from https://standards-oui.ieee.org/oui/oui.txt so that the mac addresses is used for classifying the device if the HTTP TLV Caching or DHCP TLV Caching don't pick it up.    I seem to have a huge percentage of devices marked as Unclassified or Unknown but if I look up the mac, it easily finds the correct vendor in most cases...
5 Replies 5
balaji.bandi
what is the IOS XE code running, have you looked the below guide :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215661-in-depth-look-into-client-profiling-on-9.html
if that is already looked and still issue, can you provide some example and environment information. (other than just WLC 9800 )
BB
I'm running 17.12.3 and yes I have looked at that document.  Step 1 says it looks at the OUI database
An example is a device that starts with MAC 04-C1-03 is showing as Un-Classified Device.  Yet when I look at the OUI list it identifies the vendor as Clover.
I am guessing the WLC is not actually looking at the MAC and it is only doing step 2/3 where it is looking at the headers of http traffic to determine a vendor and that is a guess at best.
Another example is a device starting with MAC 00-24-06 is identified as Linux Workstation yet the OUI lookup shows the vendor as Pointmobile.
I am guessing the 2nd device is starting with some https traffic that can identify the OS as Linux based whereas the 1st device is maybe establishing a vpn tunnel from the get go so it can never identify the device via http headers...
With MAC randomization, a lot of devices don't match for what the oui table has but I guess that is to be expected..
Overall I typically see 40% of the devices as unclassified or unknown.
did you select device classification ??
MHM
Yes I have those settings.
The system seems to classify about 60% of the wireless devices.  Of that 60%, I don't think it is very accurate.
Maybe it is a lost cause...
Leo Laohoo
OUI cannot be updated in IOS-XE.
There was talk about bringing this feature back in IOS-XE but it is "in the roadmap" since the first two years 9800 were shipped.
NOTE:
And the Cisco phrase "in the roadmap" is a both a convenient excuse and a euphemism for "not a priority unless some big customer makes it so".  "in the roadmap" timeline is between "seven to 20 years".  If the enhancement request is made by a very large customer considered "too big to refuse" then the timeline goes down to about two to three years.
I suspect one of the critical reason why this feature will not be rolled out to multi-WNCD controllers is because uploading a large OUI DB will cause a multi-WNCD controller to an uncontrollable boot-crash-loop (with or without APs attached).  Also, uploading an OUI to a VSS pair will absolutely guarantee BOTH controllers may/will go into an uncontrollable boot-crash loop.
