DHCP and Static IP on same WLAN
simmonj
Hopefully this will be an easy and straightforward question to answer: Can I setup DHCP assigned IP addresses and Static assigned IP addresses simultaneously on the same WLAN? Assumming that static addresses are already allowed on the controller/WiSM, is it simply a matter of unchecking the "DHCP Addr. Assignment Required" box in the DHCP section of the Advanced WLAN setup page? Thanks.
Scott Fella
Yes you can have static and dhcp on the same SSID. Like you said... just uncheck the DHCP Addr Required. Make sure the DHCP scope doesn't overlap with the static usrs.
-Scott
Scott Fella
-Scott
