WLAN Controller/ACS Not Authenticating
I have 2 WLAN Controllers in different cities. When I authenticate via the 1 to a local ACS server it works but from the other one I get "EAP Type not Configured" on the ACS logs. Both on the same OS, same ACS server and identical configuration. Only difference is one is 4402-12 and the other 4402-25.
Any Ideas?
Scott Fella
It doesn't seem like your configurations are correct. Check the ACS policy for both AAA clients.
-Scott
Where would I check this policy? I have added both devices in as clients and the way they are added is identical. Please advise
Problem Sorted.
The issue was with the certificate on the ACS device as well.
Uploaded a new CSR to the CA, signed it and uploaded it onto the ACS. Also installed a new cert from the CA on the user machine and all is working now.
