dhcp for User in flex mode.
r.sagredo
hi all, we are installing aps on wlc with flex-connect mode. have some doubts about the dhcp for wireless users. can the WLC in flex model work as dhcp? or whenever the dhcp for wireless users must be out of wlc? thanks to all
Stephen Rodriguez
No, you'll want to configure an ip-helper address at L3 and point to your normal DHCP server for the FlexConnect Users
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Tranks Steve,
then users can use flex-connect the WLC as DHCP? ... is advisable to do that?..
Tranks
Moin Ilyas
Level 4
Level 4
Figure 15-1 FlexConnect Deployment
That's a typical FlexConnect Deployment. The DHCP Server is advised to be at the Remote Site in a Typical Deployment.
Please refer the following link for more details.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_flexconnect.html
Hope that helps.
