WLC 2500 DNS Setting Location
melissa.jaffray
Where can I find the DNS setting information on the web interface for the WLC 2500 controller? I just have the basic setup without any special interfaces or anything. Thanks!
7 Replies 7
Sandeep Choudhary
As per my knowledge you can only set the hostname on wlc at virtual interface.
Go to Controller > Interface > Virtual Interface
see the screenshot:
or you wanted to ask about  DNS server in order to return WLC IP addresses to the LAP ?
Dont forget to rate helpful posts
I'm sorry if I sound a bit dense on this but here is my problem:
I have the controller and the AP's working fine, but I can not get to the actual internet, only the intranet. I think this is because I need to set the DNS servers to 75.75.75.75 and 8.8.8.8. I just can't find where I would do that on the web interface for the controller and since I finally have it working I'm reluctant to go poking at things just to see what they do. Thanks!
ohkk I think you need to add DNS server ip address  in dhcp scope.
Go to Controller->Internal DHCP Server->DHCP Scope and then click on name of the dhcp scope in which you want to add DNS IP address.
see the screenhot and put the dns server value  there.
I didn't have anything in the section so I created one, but what is the network setting supposed to be? Thanks!
ammahend
is you controller also working as DHCP server as well ??
-hope this helps-
No we have a dhcp server, although most of the ip's are going to be statically assigned. I tried the suggestion above, but it doesn't seem to have helped. I've attached a screenshot of my setup. Thanks!
Moin Ilyas
Level 4
Level 4
Hello Melissa,
As you said you would have Static IPs, I would suggest you to have a look at the following document.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0MR1/configuration/guide/wlc_cg70MR1/cg_wlan.html#49981
In particular, please have a look at 'Configuring DHCP' Section.
Security Considerations
For enhanced security, we recommend that you require all clients to obtain their IP addresses from a DHCP server. To enforce this requirement, all WLANs can be configured with a DHCP Addr. Assignment Required setting, which disallows client static IP addresses. If DHCP Addr. Assignment Required is selected, clients must obtain an IP address via DHCP. Any client with a static IP address is not be allowed on the network. The controller monitors DHCP traffic because it acts as a DHCP proxy for the clients.
Hope that helps.
