dhcp issues over wireless
Suresh Varghese
Level 2
Level 2
hi,
i have a windows dhcp server in vlan 6 (inside vlan)
i have configured 3 scopes in this dhcp server, all on different subnets
the vlan gateway for each WLAN is on my core 45xx with smart-relay enabled globally and ip helper-address command given in each vlan configuration.
my inside vlan dhcp assignment to users over wireless is working
the other 2 vlans are not able to get dhcp assignments.
please assist if anyone has any inputs or solution to this case.
regards
Scott Fella
Have you tested the clans with a wired device to verify its working?  If you have a WLC, by default it will proxy the DHCP request unless you disable that. Now on the dynamic interfaces of the WLC, did you specify the IP address of your DHCP server's?
-Scott
-Scott
i have tested the laptop by connecting it to both respective vlans on the core 45xx but i dont get ip through the dhcp server, but if i put static IP from that subnet and connect it thru wire into that vlan then it works.
Yes i had tried putting the IP address of the dhcp server on the dynamic initerfaces on the WLC but was not working still.
I have attached screen shot from my WLC 2125 of one of the vlans which is not working
