DHCP Problem with 4400 Controller
marknigh1
Level 3
Level 3
I have issues with wireless client receiving DHCP address on a particular VLAN. The DHCP server for this WLAN is also the default gateway (PIX).
Here is my configuration.
AP-Manager: 10.0.1.100
Management: 10.0.1.101
SSID: Guest
Dynamic Interface: VLAN990
The Dynamic interface is configured as follows: 10.192.168.254, 255.255.255.6, G/W 10.192.168.1. Primary DHCP Server 10.192.168.1.
When I use static address for wireless clients, all works well. When I configure a internal DHCP server, all works well.
The debug message I receive is that a DHCP request received on a directly connected port must be sent to a external DHCP server (10.192.168.1). No response from the PIX (DHCP Server).
Can it be the PIX not responsing to the DHCP request since it is a DHCP Relay message?
Your help is appreciated.
Mark Nigh
Benjamin Solero
Hi Mark,
This is a common problem and you are dead on correct with your suspicion: The PIX does not reply to requests from DHCP Relay Agents (which is what the controller is doing). Therefore, you have to either choose an alternate DHCP Server that DOES support requests from a DHCP Relay Agent OR go with the internal scope on the controller.
-Ben
