DHCP scope per WLAN on WLC
Atsushi Ikeda
I want to use the internal DHCP server on WLC 2504,
and devide a VLAN ( i.e., DHCP Scope) per WLAN.
How can I configure it ?
I want to know also about interface settings.
Thanks.
Atsushi Ikeda
Sandeep Choudhary
Ues interface Groups.
check this post:
https://rscciew.wordpress.com/2014/01/22/configure-dynamic-interface-on-wlc/
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0100110.html
Dont forget to rate helpful posts
Sandeep Choudhary
check this post:
Thank you for reply.
I could do it by using interface group and dhcp link select.
Atsushi Ikeda
If you are satisfied with the answer then please mark this question as answered, it may help others. Regards Don't forget to rate helpful posts
mohanak
Configuring DHCP
You can configure WLANs to use the same or different Dynamic Host Configuration Protocol (DHCP) servers or no DHCP server. Two types of DHCP servers are available: internal and external
This section contains the following topics:
Internal DHCP Server
External DHCP Servers
DHCP Assignment
Configuring DHCP
Configuring DHCP Scopes
