DHCP services on Wireless LAN Controller
stephenstown20
Level 2
Level 2
hello
we need to reserve an IP address on a DHCP pool configured on a Wireless LAN Controller appliance configured for Guest user wireless services
Q is it possible to create a DHCP reservation on the WLC ?
RoadRunner4k
Level 5
Level 5
If its a Catalyst WLC 9800 then yes you can create a DHCP pool. But it requires an interface on the box.
Cisco Catalyst 9800 Series Wireless Controller Software Configuration Guide, Cisco IOS XE Dublin 17.12.x - DHCP for WLANs [Cisco Catalyst 9800 Series Wireless Controllers] - Cisco
From 17.13 there is support for VRF definition on the DHCP pool.
balaji.bandi
I would suggest to use external DHCP Server , so WLC can do their job as expected.
Any way you need to Radius for Guest user for authentication.
BB
