different IP addresses for same AP
vishalpatil86
Level 7
Level 7
HI,
i have configured autonomous AP with IP 172.16.10.127 and brought it in network
it is directly connected to core switch. when i do sh cdp neighbor gig6/8 detail, it is showing IP address of AP as 172.16.10.68.
help on this..
Surendra BG
ok!! get the access to the AP and assign the IP address again manually..
en
conf t
int bvi 1
ip addr
no shut
end
See if we are still able to get other IP addr..
Surendra
Surendra BG
hi surendra,
when i got console and do sh ip int br, it showed -
Interface                  IP-Address      OK? Method Status                Prot
ocol
BVI1                       172.16.10.127   YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio1                unassigned      YES NVRAM  administratively down down
FastEthernet0              172.16.10.68    YES NVRAM  up                    up
fastethernet was different.. how it was something different?
i configured this AP from web interface.
thanx for the help
Your management IP address should be the BV1 and not the FastEthernet0.  You don't need to assign an IP address to the FE.
As leo stated. the IOS AP should be assigned the IP on BVI interface not any where else!!
Surendra
Surendra BG
