Bookmark
Subscribe
1429
different speed test via two phones
Dhikra Marghli
Level 5
Level 5
Hello
we will test the throughput of an access point and we have two phones (Glaxay A10 and Hawuei)
the problem:
why if we are  in the same position to test the throughput ( speed test via phone ) ,
the two phones (  (Glaxay A10 and Hawuei)  give different speed test and different throughput  despite they are in the same place  .
PLease , i need from expert wirless explain me why the two phone in the same place give different speed test
(   Glaxay A10 give  high speed and the other phone hawei give  low speed  )  i the same position that a allows us to hesitate for our work !!!
thanks in advance
Speed Depends on the phone models and vendors.
Not every phone support high throughput (802.11ac or 802.11n).
Check Which phone is connected to which protocol(802.11ac or 802.11bn..etc)
Reagrds
Dont forget to rate helpful posts
7 Replies 7
marce1000
 - What is your wireless environment, controller based or standalone ? Include controller-model + ap-model + software versions used, etc,..
 M.
No
i ask  about  why we have different speed test throught two phone in tha same position to check  speed test  !!!
wireless based controller !!!
Reagrds
thanks to reply
the phone Glaxy A10 support band 2.4GH and give  high throughput  and  Also the Phone huawei  suport band  2.4GHZ
  give low speed test   ....the two  phone are in the same position to check speed  test !!!
SO what is the reason  that in the same position   , they give  different speed test !!
thanks in advance
What Cisco equipment do you have, like what was asked previously? You need to always post the details to what controller, access points and code you are running. Then also post some details with screen shots of the issues.
-Scott
@Sandeep Choudhary
I check and i Tell you !!
Thanks to Reply me
Different devices are different hardware and software so you cannot compare them!
They probably have different chipsets, antennas, MIMO capabilities and each vendor has their own customised version of Android - you need to check the device specs. If you have 2 identical devices (same hardware and software) then you can compare them.
