Different VLANs for Wireless users
Asfandyar70754
Level 4
Level 4
Hello everyone,
Currently I am using CIsco 3k switches and Cisco Meraki APs in my environment. We have few printers too.
We have 4 departments in our office and about 50 users.
I wanted to make 4 Vlans for each department and assign 1 printer to each department, currently I don't have an AD(but I am planning to get one soon).
I need suggestions how do I implement this.
balaji.bandi
Are you looking for all the users to connect Wireless and print?  how many SSID you have?
BB
Right now all users are on wireless in single vlan and they can use any printer.
I want to separate users and printers department wise.
For eg: users of vlan 10 can use only Printer A, and users of vlan 20 can use Printer B.
I have 4 SSIDs right now I can add more to if needed.
The much better solution would be to use a radius server and then push the VLAN to the WLC when the user authenticates (with username+password). Here an example with a free Linux based radius server:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/211263-Configure-802-1x-PEAP-with-FreeRadius.html
Or Windows NPS:
https://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/115988-nps-wlc-config-000.html
balaji.bandi
If they are 4 SSID, and you can create 4 VLAN so printer stay respecteer VLAN, but any user can reach any IP address in the LAN.
Other option if you have different SSID with different IP address spool. ACL is best option to block other IP block to contact non authorise printing services.
take example
create an ACL printer 1  - only x.x.x.x /24 can acces x.x.x.10 (printer IP) rest deny so on
is this make sense ?
since you do not have any print server in place or AD based available now.
BB
