disable idle timeout on WLAN
Hi Team,
If user idle timeout uncheck on WLAN means no idle timeout happens to user if connectivity is idle
5 Replies 5
Yes that correct
but if you disable it in WLAN Guest then your DHCP will exhausted fast
you need to be careful
MHM
Mark Elsen
              - Include the controller model too (?)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Models are 9800-80
    - Use these advisories : https://community.cisco.com/t5/wireless/ideal-wlan-timeout-settings-9800cl/m-p/4412468#M230030
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Refer Client Timers section from following Cisco Catalyst 9800 series configuration best practices document
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#clienttimers
Jagan Chowdam
/**Pls rate useful responses**/
