Disabling SNMP on 350APs using VxWorks
pwhiteley
Community Member
I need to disable SNMP on our complement of 350 APs. However, I've tried the normal route of disabling via the SNMP parameter (web) page but if I go back to the APs a day later somehow SNMP has re-enabled itself. I've tried turning off CDP to help the process but that didn't work either. Anyone else come across this problem (and have a solution for it)?
Thanks in advance for your assistance with this matter.
rmushtaq
Level 11
Level 11
Under Setup->SNMP, disable SNMP and also under User Manager, for the user, un-check the SNMP box as well.
That doesn't work either! I removed two users from User Manager, unchecked SNMP from the remaining user, went back to the SNMP page, disabled SNMP, applied it, OK'd it. Today, in the user's profile the SNMP box is checked and SNMP is once more enabled. I'm one of only 2 people who has Administrator access to our APs so it's not someone messing us about. I've seen this phenomenom on our 350s in the past and thought nothing of it but now I need to get SNMP disabled. Any other suggestions? Our 350s all run firmware version 12.4. Thanks.
