Do I need a WLC for Indoor Mesh (AP1240)?
Roneel Ram
    I want to start implementing a small indoor mesh network of 3 APs Aironet 1240(Currently in standalone mode) in order to grow afterward with more APs. Is there any way to configure those 3 APs in an indoor mesh configuration (for example, only one RAP and two MAPs) without a Wireless LAN Controller? We might be getting a WLC 2500 series controller but attthe moment i don't one.
This is i a warehous deployment therefore limitations in running cables.
Ron
George Stefanick
Yes, you will need a controller ...
http://www.cisco.com/en/US/docs/wireless/technology/mesh/design/guide/MeshAP_52.html
michaelgitonga
Riaan,
Yes you will need a Wireless LAN Controller. Also, you will need to convert the 1240 standalone APs to Lightweight Mode.
Don't use Tilgin
Abhishek Abhishek
Hello Ron,
As per your query i can suggest you the following solution-
Yes, you need a WLC for Indoor Mesh (AP1240).
Hope this will help you.
