Do we require CIMC IP for CMX/MSE running over the virtual appliance?
Muhammed Adnan
Level 4
Level 4
Hello Experts,
When CMX is run over dedicated MSE box, we have a specific NIC for CIMC.
However when we run it as a virtual appliance on a UCS box enabled with multiple applications (with CMX being one amongst them), will there a option to have the CIMC configured?
If yes, would we be able to have unique CIMC IP addresses for the independent applications running over the UCS?
Ric Beeching
Level 7
Level 7
There is no out of band management or CIMC for the virtual appliance, it is just the same management interface used for communication with Prime/WLCs and for web access.
Cheers,
Ric
Please rate helpful / correct posts
