Does there anyway to set maximum clients per WLAN SSID
ALI12
Hello Team,
Model : AIR-AP1815I-I-K9
Software Version :8.4.100.0
Seems like it isn't possible to configure while your WLAN is active.I would recommend to configure a new WLAN for test purposes, disable it, and try to configure the max-clients, just to clarify that it is possible.
9 Replies 9
Thanks @Kasun Bandara for your reply ,
but unfortunately  I have  no option to set maximum client as per attached Print-screen
nict
Hi Ali,
Are you using this AP1815 as an autonomous AP/Mobility Express or as an Lightweight AP connected to a WLC?
Mobility Express Controller
As described in the link Kasun links, have you tried connecting to the AP via the CLI instead of the GUI and do the following?
Configuring the Maximum Number of Clients per WLAN (CLI)
Step 1
Determine the WLAN ID for which you want to configure the maximum clients by entering this command:
show wlan summary
Get the WLAN ID from the list.
Step 2
Configure the maximum number of clients for each WLAN by entering this command:
config wlan max-associated-clients max-clients wlan-id
ALI12
Thanks @nict for your reply
I got below:
WLAN/Guest-Lan/remote-lan is enabled.Please disable to configure max associated clients.
yes thanks @nict
configured after disabled it
Thank you very much @nict
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum Clients Allowed.......................... 2
Awesome - Glad I could help!
