Does work a MSE over the WAN?
barny8874
Has anyone experience if a MSE works over the WAN?
Scott Fella
Sure.... if your talking about just for context aware.... if your looking at CMX, then no (the new release I believe).  Depending on the services you will be using, you need to look at the deployment guide to see the restrictions about connectivity.
Scott
-Scott
Sandeep Choudhary
adding to Scott.
Normally Its recommanded that MSE should not be connected to WLC or NCS on a WAN connection.
Let me clarify this also... I'm talking about a high speed link WAN in which you may have data centers with WLC's located at the building and MSE an PI in the datacenter.
Scott
-Scott
Thanks for the replies. In my solution it comes to nationwide Wi-Fi in an amusement park (about 10,000 visitors a day). The MSE / CMX to be used for marketing purposes. The Internet currently has a bandwidth of 34 Mbps. Did you experience what is the traffic between the WLC and MSE with so many clients?
Andre
