NCS - error when trying to move Wireless Map
Michal Pytlak
Visitor
When I'm trying to move building to new campus I'm getting below error:
Error(s): You must correct the following error(s) before proceeding:
Error:Unknown Exception Occurred. If the problem persists please send logs to the Tech Support.
Error:Detail: Row was updated or deleted by another transaction (or unsaved-value mapping was incorrect): [com.cisco.server.managedobjects.servicedomain.ServiceDomain#476477]
Can someone advice please?
5 Replies 5
Ric Beeching
Level 11
Level 11
Hi Michal,
Unfortunately that's quite an ambiguous error. Your best bet would be to log a TAC case with Cisco straight away I think and they can investigate the issue for you.
Kind regards,
Ric
Please rate helpful / correct posts
Thanks Ric
Hi Michal,
Did this issue get resolved by tAC for the below issue you had?
"NCS - error when trying to move Wireless Map"
Bob Bagheri
Level 4
Level 4
I'm getting the same error on PI 1.4.0.45.
Any luck resolving?
Bob Bagheri
Unable to move buildings to a new Campuses (occurs on random buildings)
CSCul23421
Symptom:
Prime Infrastructure may throw an exception when trying to move buildings between campuses, stating that the row was updated or deleted by another transaction.
Conditions:
Workaround:
At this time, there is no workaround.
Further Problem Description:
