#DOT1X-3-INVALID_WPA_KEY_MSG_STATE: 1x_eapkey.c:864 Received invalid EAPOL-key
ahmed.sabri
Hey Cisco members,
I got lot of logs as mentioned in the subject on WLC 5508 (7.5.102.0) WPA2 with AES. I did the following actions:
1- "config advanced eap bcast-key-interval 86400".
2- Updated my wirless driver.
3- increased the timeout for EAP.
A.Sabri
Though it is not directly related to this issue, it is highly recommended to move onto a supported WLC software code.(either TAC recommended 7.6.130.x or 8.0.120.)
Do you get user complaints about connectivity due to this ?
Rasika
*** Pls rate all useful responses ***
Random disconnection every day for 3 or 4 users.
Hi Ahmed,
Any workaroud on this issue ? How did you get rid of this ?
thank you
Florian
