Doubt about Led status in AIR-SAP1602I-N-K9
I have a new 1602I AP, in the past I have configured other cisco APs (1242, 1250, etc) and when I have carried out the first tests in order to know if there is a client associated to them, I just looked if the led color is blue..
In this model I noticed that led color keeps green when clients are associated to AP,  now I have two client associated.
Does any of you know if this feature  was remove in this AP model?, or there is a problem with version 15.2(2)JB2
Regards.
Rasika Nayanajith
Cisco has change the behaviour in these AP models (may be due to cost factor) compare to previous one. You can see the below in table 1 of the reference link provided
http://www.cisco.com/en/US/docs/wireless/access_point/1600/quick/guide/ap1600getstart.html
Chirping Green
Normal operating condition, but no wireless client associated
Green
Normal operating condition, at least one wireless client association
So what you see is normal with this AP model.
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Chirping Green
Green
Rasika
Hi Rasika,
thanks a lot for your quick response, and thanhs for the link.
regards
Sorry I'm french and i dont understand "chirping", is it like blinking ?
Yes it is:)
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
