11-15-2012 09:34 PM - edited 07-03-2021 11:03 PM
Hi all,
I would like to downgrade Cisco Aironet 1142N to autonomous. But I would like to know is there any way to download the LWAPP IOS before upload the Autonomous IOS ? because I want to upgrade the 1142N from autonomous to LWAPP when I buy a LAN Controller.
Is that possible to use that backedup LWAPP IOS when I want to upgrade the Cisco Aironet 1142N autonomous to LWAPP?
Thank you in advance
Chamara
11-16-2012 01:47 AM
Go to the Cisco website and download the RCV file.
11-19-2012 01:14 AM
Hi is this possible on all type of AP? i have 3500 series CAP. and i need to convert it to Autonomous since i dont have a controller yet.
11-19-2012 02:12 PM
Yes it's possible and I've also responded to your thread/post.
11-26-2012 02:54 AM
Thank you for the reply. But it is not clear to me. my apology about that(I'm newbie to these things)I tried to download IOS from Cisco site and it required a contract. Since I thinnk I have to buy the IOS from a reseller. Am I right? Can you please clarify the steps how to backup the old IOS before upload new autonomous IOS ?.
11-26-2012 04:47 AM
If you don't have a smartnet contract tied to your CCO for that device, you will not be able to download any code. You can ask the vendor who sold you it for the code.
How do change the code you can find on the Internet. Here is one way
http://m.youtube.com/#/watch?v=QQ_NuxdRhQ4&desktop_uri=%2Fwatch%3Fv%3DQQ_NuxdRhQ4
11-26-2012 06:42 PM
Thanks Leo, i will try it this week to check if it works.
Also thanks to you Scott.
11-18-2021 05:04 AM
Tag(s) Added: I searched a lot but did not get.. Please send me the link... jeet_nawal@yahoo.co.in
11-29-2012 08:00 PM
Thhanks scott. I'll try to understand.
11-29-2012 08:02 PM
No problem. Hopefully they get you the image you need.
03-04-2014 12:42 AM
I have AIR-AP1242AG-K9 with LWAPP firmware, but I'dont have controller
So, How to set an IP Address to this AP when I want to transfer file from FTP ?
thankyou
03-04-2014 01:44 AM
do you want to change it to autonmous mode ?
first you need W7 image to run on AP.
Check this links to convert:
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Hope it helps.
Dont forget to rate helpful posts
03-04-2014 01:46 AM
Hi Dani,
This posts should help you on this
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
**** Pls rate all useful responses ****
