Download Aironet 350 Wireless LAN Adapter Firmware - Need v.5.30 or Higher
ArchiMark
Hope someone can please advise.
I need to update the firmware on my Aironet 350 Wireless LAN Adapter PC Card. I want to use it in some older laptops.
Have tried to find it on the Cisco website, but no luck so far....links I found so far do not work.
Thank you for your help.
Mark
5 Replies 5
Leo Laohoo
This firmware is no longer hosted by Cisco because the product is End of Support.
The only choice is to search the web using the complete file.
I'm not sure if this is helpful to you, you can get it if it is useful, thank you!
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Just realized file you uploaded is for Broadcom, not Cisco......
ArchiMark
Thank you both for your replies.
Yes, know that product is old and EOL.
However, don't understand why that means Cisco won't let me download the file. Other companies will do this.
Thank you, Rps-Cheers fro sharing the file, but it is for Broadcom, not Cisco.
As far as I remember, it's just a rebranded adapter and the alternative driver should work.
