06-25-2019 10:26 AM - edited 07-05-2021 10:36 AM
Hello All,
When enabling TCP MSS under Wireless > Access Points > Global Configuration, will the APs reboot when I click apply?
Also, under Cisco's WLC Configuration Best Practices, it says: "In general, a 1300 bytes value is a good average, although it can be further optimized depending on your setup.".
Does that still hold true, should I set it to 1300?
Thanks in Advance,
Matt
Solved! Go to Solution.
06-25-2019 01:55 PM
Any changes in related MTU to take effective of new MTU it required reboot.
06-25-2019 11:36 AM
good documetnt for reference :
06-25-2019 11:44 AM
06-25-2019 01:42 PM
when you enable TCP-MSS Globally, a reboot is required
I believe the command to show the TCP-MSS is > show AP tcp-mss- adjust all
I hope this helps
06-25-2019 02:24 PM
06-25-2019 01:55 PM
