DP Packet pool and WQE pool is not normal
myhost1016
some of ap will re-jion my AC
my AC logs:
Time: Oct 15 14:03:41
Facility: local0
Priority: emerg
Tag: BHKJ_WLC
Message: *broffu_SocketReceive: Oct 15 14:05:55.051: %BROFFU-0-DP_PACKET_WQE_DIFF: broffu_fp_dapi_cmd.c:6348 Warning: DP Packet pool and WQE pool is not normal. DP0 Current PacketBuffer=68 Current WQE = 76361
Time: Oct 15 14:07:41
Facility: local0
Priority: emerg
Tag: BHKJ_WLC
Message: *broffu_SocketReceive: Oct 15 14:09:55.147: %BROFFU-0-DP_PACKET_WQE_DIFF: broffu_fp_dapi_cmd.c:6348 Warning: DP Packet pool and WQE pool is not normal. DP0 Current PacketBuffer=62 Current WQE = 76475
Scott Fella
Have you searched the big tool kit?  It seems that this has no affect on ap joining or not.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh79685
You may want to search around for that message and see what others have posted about it, troubleshoot the ap issue more and or open a tac case.
-Scott
Rich R
What model of AP?
What model of WLC?
What version of software are they running?
As @Scott Fella has pointed out there is a known bug for these log messages (cosmetic only) so if they're bothering you and you're running an old affected version then you should simply upgrade to a release with the fix.
Recommended AireOS Wireless LAN Controller Releases - Cisco
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
