Drawbacks for A Disk clean up
Ahmed Ayaad
Level 3
Level 3
Dears,
i have prime infrastructure 2.0 and i need to do the following command on it but i dont what is the drawbacks for this commands(
ncs cleanup, ncs db reinitdb ) if used this commands site maps or access point or any reports will be deletes or not.(i need down time or not)
Also i have host memory consumed issue in PI VM if i use the above two commands the problem cleared or not.
Disk cleanup will not delete the maps, etc. you do have to shut down the NCS service when doing a cleanup.
-Scott
5 Replies 5
Stephen Rodriguez
NCS clean up goes in and removes archived files and does general cleanup if the disk.
The db reinit however puts the database back to default. I wouldn't run that command unless you absolutely had to
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
please advice if this commands will delete the Site maps, Reports..... , also advice if this commands need down time or not
-Scott
what if its an HA setup.  are the steps same?
Hello, Scott!
What about Prime with HA, how is the cleanup procedure? Should the HA be removed first? Coz HA takes a while to build if it is removed.
Thanks!
