Easy Wireless 802.1x solution
MIsatchenko
Hi All,
Looking for an easy way for our students to connect to our wireless. Our current setup is using WEP with PEAP and AD.
We use WLC's and ACS and AD.
We basically want it set up as easy as possible so that our students can connect with no problems.
Any suggestions?
Any programs out there that will push config to the users?
mike
Level 2
Level 2
If you truly want it to be as easy as possible on the students, why have security at all on the wireless network?
I'd segregate it from the normal network using VLANs. In order for the students to then access internal resources, they'd need to VPN into the main network. That not only encrypts their traffic better than WEP can, but also makes it easy for them to connect quickly and with few issues.
