?when does marginal performance become unacceptable
steve.dutky
Level 2
Level 2
Dear all,
I have an issue with a desktop supplier:
The desktop's integral wifi b/g adapter routinely drops about four out a 1000 1000-byte pings from the next-hop gateway through an ap1130 a/g. (for the record, plenty of bandwidth, resources, no problem seen with 3rd party WiFi adapters, usw)
I think this sucks and that he should fix it. He thinks differently.
Can anyone suggest an acceptable threshold for this?
Thanks.
owillins
Level 11
Level 11
Could you please give brief discussion about your topology and features detail.
This has a simple sandbox topology:
1130 A/G ap with autonomous IOS trunked at 100/full to a 3550 l3 switchport
I have configured the ap with 3 ssid's, all open authentication, one guest-mode, the other two with 128 bit wep keys.
Each ssid has a corresponding svi/vlan on the switch as a next hop.
The integral adapter drops about 4 in 1000 on the G channel no matter to which ssid it connects.
Please note I don't see any packet drops using other wifi adapters on either A or G frequencies.
Again I'm looking for a rule of thumb. Can you live with losing 4 packets out of a thousand? If yes, how about 1 out of a hundred? If no, how about 4 out of ten thousand?
4 packets out of a thousdand seems acceptable to me. That's a failure rate of less than half a percent.
