Embedded controller problems after Update on 9115 ap
netlevelag
Community Member
Hello Everyone
I have a C9115 that i converted to EWC Using ap-type mobility-express tftp://10.1.202.111/9100/ap1g7 tftp://10.1.202.111/9100/C9800-AP-iosxe-wlc.bin
The device came back up in recovery mode and i tried installing the binary using this command: archive download-sw ewc-ap tftp://10.1.202.111/9100/C9800-AP-iosxe-wlc.bin
The download stops dead at 78%
I think that the flash is full and I found this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvt44832/?rfs=iqvred
When I try and list the cores I get this:
#show flash cores
Directory of /storage/cores/
total 0K
Directory of EWC-AP core files
Directory does not exist!
Filesystem Size Used Available Use% Mounted on
/dev/ubivol/part2 520.1M 497.8M 22.3M 96% /part2
Any help would be welcome. Thank you
17 Replies 17
Mark Elsen
 - I have been following up on this for a while , more and more I think the tftp-client on this particular ap-model is buggy. Could you use FTP instead ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I have seen that in some threads and I tried. This is the output:
#archive download-sw ewc-ap ftp://cisco:[email protected]/tftp/9100/C9800-AP-iosxe-wlc.bin
Error: ftp to be implemented in image_download.sh.
Checking .../part2/wlc/images/C9800-AP-iosxe-wlc.bin doesn't exist!
 Tx, for the feedback  , are there any other download protocols available ? Usually can be  show with command completion request ?  when you arrived at the relevant part of the command.
 M.
Only tftp and
AP34ED.1BDA.81E4#archive download-sw ewc-ap
WORD URL of eWLC image <tftp|sftp>://<server_ip>/<file_path>, or 'rollback'
to load previously-used eWLC image
So I changed it to: archive download-sw ewc-ap sftp://cisco:[email protected]/tftp/9100/C9800-AP-iosxe-wlc.bin
and it got to:
AP34ED.1BDA.XXXX############################################################### 87.4%
AP34ED.1BDA.XXXX#ransfer command failed (Error 23)
I am sure that it has to do with the bug above. This is the result from show flash:
AP34ED.1BDA.XXXX#show flash
total 84K
-rw-r--r-- 1 root root 2 Nov 25 00:10 BOOT_COUNT
-rw-r--r-- 1 root root 2 Nov 25 00:10 BOOT_COUNT.reserve
-rw-r--r-- 1 root root 29 Nov 25 00:10 RELOADED_AT_UTC
drwxr-xr-x 3 rsyncuse root 224 Nov 25 00:10 application
-rw-r--r-- 1 root root 303 Nov 25 15:54 base_capwap_cfg_info
-rw-r--r-- 1 root root 2 Nov 25 00:10 boot_debug
-rw-r--r-- 1 root root 10366 Nov 25 00:11 bootloader.log
-rw-r--r-- 1 root root 5 Nov 25 00:10 bootloader_verify.shadow
-rw-r--r-- 1 root root 18 Nov 25 00:10 config
-rw-r--r-- 1 root root 0 Nov 25 00:10 config.local
-rw-r--r-- 1 root root 0 Nov 25 00:11 config.mobexp
-rw-r--r-- 1 root root 0 Nov 25 00:11 config.oeap
drwxr-xr-x 2 root root 160 Sep 27 2019 cores
drwxr-xr-x 2 root root 160 Jan 1 1970 dropbear
drwxr-xr-x 2 root root 160 Nov 25 00:10 firmware
-rw-r--r-- 1 root root 251 Nov 25 00:17 last_good_uplink_config
drwxr-xr-x 2 root root 160 Sep 27 2019 lists
-rw-r--r-- 1 root root 18837 Nov 25 00:10 nvram_setting
-rw-r--r-- 1 root root 63 Sep 27 2019 part1_info.ver
-rw-r--r-- 1 root root 218 Sep 27 2019 part2_info.ver
-rw-r--r-- 1 root root 4096 Nov 25 00:16 random_seed
-rw-r--r-- 1 root root 3 Nov 25 00:10 rxtx_mode
drwxr-xr-x 2 root root 648 Nov 25 00:10 ssh
drwxr-xr-x 3 1 root 224 Sep 27 2019 support
drwxr-xr-x 2 root root 4144 Nov 25 00:41 syslogs
-rw-r--r-- 1 root root 1 Nov 25 00:11 wips_adminstate_capwap
/dev/ubivol/part2 520.1M 520.1M 12.0K 100% /part2
The Flash is full and can't download the image.
                 - What's in the logs of the sftp-server when this happens ?
 M.
Not much. Only: SFTP client [admin] from [10.1.202.105] logged out the server with totally [0 Bytes] uploaded and [216.24 MB] downloaded.
I am getting this on the console:
[*11/25/2020 00:24:10.1040] Going to restart CAPWAP (reason : WTP IP address changed)...
[*11/25/2020 00:24:10.1050] Restarting CAPWAP State Machine.
[*11/25/2020 00:24:10.1050] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*11/25/2020 00:24:10.1220]
[*11/25/2020 00:24:10.1220] CAPWAP State: DTLS Teardown
[*11/25/2020 00:24:10.2090] status 'upgrade.sh: Script called with args:[ABORT]'
[*11/25/2020 00:24:10.2510] do ABORT, part2 is active part
[*11/25/2020 00:24:10.2830] status 'upgrade.sh: Cleanup tmp files ...'
[*11/25/2020 00:24:10.3030] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
Is there any way I can free up space in the flash?
 - Try to run the sftp (/ssh-server) in debugging or verbose mode, check if that can give more info's
 M.
IOS XE uses "ip tftp blocksize 8192" by default to speed up file transfers, might be there are incompatibilties with the TFTP server. Normal TFTP blocksize is 512. So perhaps lowering the blocksize to a value of 1456 or even 512 fixes the issue.
OpenTFTP for example uses 512 by default and if you like to use other rates you have to set the blocksize in the ini file.
Thank you.
I have tried with Solarwinds and Synology TFTP. Could not find any settings where I could change the blocksize.
I have never had any problems with TFTP before and have also tried SFTP and it stops at 87%. I am pretty sure that the flash is full.
Any other ideas welcome!
Don't know about the one from Solarwinds but Synology uses OpenTFTP.
You need to SSH into the NAS, then:
sudo vi /etc/opentftp.ini
Press ESC
Insert "blksize=8192" into "[TFTP-OPTIONS]" section
Press ESC again
Save and quit with ":wq!"
/usr/syno/sbin/synoservicectl --restart opentftp
You can also change blocksize on IOS XE:
enable
conf t
ip tftp blocksize 512
end
That also works on IOS switches, but you should have at least LAN base image.
Thank you!
I tried that and get the same error.
curl: (71) Error
transfer command failed (Error 71)
I am going to RMA the device.
 - I have been struggling to understand which models do EWC , yours may not :
            https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
 M.
Yes it does. That is why there is a EWC Firmware for the device. You can easyly look it up by googling the product with the EWC Part in it.
