Embedded Wireless Controller install fails
Minoru Ohkubo
Frequent Visitor
Frequent Visitor
Model:C9120AXI-Q
Install EWC on C9120 running with CAPWAP as shown in the attached log, but the installation fails.
It looks like you're getting an error like out of storage space.
Is there any good way?
Scott Fella
You are suppose to unzip the file and then look at the readme to determine which bin file to use.
-Scott
Minoru Ohkubo
Frequent Visitor
Frequent Visitor
Thank you for your response.
I understood the contents.
Certainly, it was implemented in the following way and it worked.
ap-type ewc-ap tftp: // <TFTP Server Addr> <AP Image File Name> tftp: // <TFTP Server Addr> <EWC Image File Name>
Thank you very much.
Scott Fella
Glad that helped.
-Scott
