Showing results forĀ
Search instead forĀ
Did you mean:Ā
Enabling Redundancy on 9800 WLC With VSS switch
ahmad.syed
Hi Team,
I am deploying 9800 WLC , which is going to use  Single VSS switch (or stack/VSL pair/modular switch) with RP back-to-back as per below connectivity. Need support for config related to LAG on WLC and switch . Please help
Ports from each WLC go to a port channel on the VSS Switch
Port Channel Numbers do not have to match on VSS and WLC - although some people prefer that but may not be possible dependant on port channel IDs already in use on VSS switch.
WLC
WLC(Config)#interface range XX - XX Interfaces on WLC to be part of Port Channel
WLC(Config-if)#switchport mode trunk
WLC(Config-if)#switchport trunk allow vlan <XX> If restricting VLANs
WLC(Config-if)#Any other port config you require
WLC(Config-if)#channel-group <X> mode on Port Channel value - can be same on both WLCs as locally significant
WLC(Config)#interface PortChannel X
Switch
Repeat twice with seperate Port Channel IDs
Switch(Config)#interface range XX - XX Interfaces on Switch to be part of Port Channel (Ensure that one is on each switch)
Switch(Config-if)#switchport mode trunk
Switch(Config-if)#switchport trunk allow vlan <XX> If restricting VLANs
Switch(Config-if)#Any other port config you require
Switch(Config-if)#channel-group <X> mode on Port Channel value - can be same on both WLCs as locally significant
Switch(Config)#interface PortChannel X
Verification same on both WLC and Switch
#Show etherchannel summary
Once completed ensure you can access both WLCs then follow the 9800 SSO deployment guide
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/9800/17-3/deployment-guide/c9800-ha-sso-deployment-guide-rel-17-3.pdf
*****Help out other by using the rating system and marking answered questions as "Answered"*****
WLC
Switch
Hi @Haydn Andrews ,
Thanks for your response.
One query, when we are doing configuration on switch end , as suggested having same port channel as WLC is not mandatory , then can we go with different port channel ID at all 4 location meaning on both WLC and both switch
The port channel ID can be different on all 4 locations if you want. The only ones that have to actually be different are the two on the switch side, otherwise technically you could have 3 x Port Channel ID 1 if you really wanted to, or 4 different ones
To add on top of this excellent reply.
1. You can use LACP for LAG's as this is supported from 17.1.X codes when WLC's are in HA.
2. You can add spanning-tree portfast trunk on the uplinks.
3. Distribute the WLC downlink ports across different modules if switch is modular or ASICs if switch is fixed chassis.
4. Use RMI+RP with Gateway reachability check enabled.
5. Configure the service ports of each box and connect it to management switch (if there)
