Enhanced POE on 3750E not available for 3602i AP with AC module
dmcgrath.ca
I have some 3602i APs with the AC module and I am looking to push 20W out of their ports for enhanced POE, but it would appear that the WS-C3750E-48PD-SF we have (Motherboard revision number : B0) will only allow up to 15.4W.
Any idea what other settings or things I might be able to find can possibly get enhanced poe enabled? Or is it just not possible on this system?
Thanks.
Thanks for the quick reply!
Actually I was just noticing that I can get the 20w if I use the command:
power inline port maximum 20000
Scott Fella
Overall PoE output depends on the hardware. Your switch only can do 15.4W max, nothing more. If you require higher PoE output, then you need a new switch that supports those requirements.
-Scott
