How often does Prime sync with DNA-C after setting up automatic sync ?
Hi all
Im trying to find out how often Prime will sync data to DNA-C when setting up automatic sync in the Co-excistence tool.
I cant quite seem to find that info anywhere.
But for example, if I move an AP on a map in Prime, how much time will pass until its also moved on the same map in DNA-C ?
Thats it
Thanks, if anyone knows, Thomas
b.angel
Thomas, to answer question about moving the AP on the map. I don't think the AP move within DNA Center. When I move or add APs on Prime I do the same on DNA Center just to keep them in sync.
Paul Dyer
 I´m about to integrate Cisco Prime with DNA but is not ready yet.  One place I´d look at is on Job Dashboard. I can´t see and job there as I dont have it integrated but in your case, I believe you may see the job there, probably under Infrastructure. You can even change the frequence.
-If I helped you somehow, please, rate it as useful.-
Sorry I cant fint that job anywhere. - So it properly does not exist in that way (unfortunately)
And if you are about to integrate, with DNA-C - I highly recommend you start with the newest PI3.8+ , previous releases have, lets say, produced "mixed" results. PI3.8+ seems to work every time.
Thanks Thomas!
b.angel
Paul Dyer
