EWC C9115AXI, SSID configuration and Vlan atribution by RADIUS
ANTONIO DEUS
Hey guys,
We bought 30 AP Catalyst C9115AXI-E, and this model has the possibility of one of the APs serving as a virtual controller, that is, Embedded Wireless Controller.
The intended scenario is to create an SSID (tono) where the vlan is assigned by RADIUS with WPA2 enterprise. The SVIs of these vlans are on a firewall. The DNS/DHCP are behind this firewall, in another vlan, not any wireless vlan.
Could someone provide an example of how to create the SSID in the EWC, where the 30 APs are registered in the EWC and the network in which each diviece gets connectivity is a different network (vlan 50, vlan 65 or vlan 650), through assignment/classification by RADIUS.
Model: cisco C9115AXI-E (VXE) processor (revision VXE) with 324133K bytes of memory.
IOS XE: Version 17.06.04
Thanks in advanced
António
This is my flex profile and policy profile:
wireless profile flex default-flex-profile
 description "default flex profile"
 native-vlan-id 1076
 vlan-name IoT
  vlan-id 1162
 vlan-name USER
  vlan-id 1032
 vlan-name GUEST
  vlan-id 1161
wireless profile policy whichever-policy-you-want-to-change
 aaa-override
11 Replies 11
balaji.bandi
check this deployment guide and step by step :
https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
3 VLAN mean you looking for 3 SSID WLAN  for different Services? as long as the VLAN and WLAN binded reset all config same 1 SSID or more SSID, only different if you have Guest Access and Web Auth.
You can make necessary FW Rules regarding what VLAN/WLAN is required and what resources are accessed/denied.
If you looking for more AP deployment, suggest having 2 EWCs (HA), in case one failed the other one becomes active.
There is a good presentation I would suggest to read and understand the flows :
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/BRKEWN-2016.pdf
EDIT :
suggest having another Good blog for reference apart from cisco I have suggested a document.
https://www.wifireference.com/2019/12/07/cisco-embedded-wireless-controller-on-catalyst-access-points/
BB
Hi balaji.bandi,
Thank you for your answer. The first link you send, I already read it, but does not help me what we need.
What we need is one SSID,for example tono, for 3 different vlan/SVI, that are assignment by RADIUS. It is possible do it on EWC on C9115AXi?
One SSID, so based on the user authentication you would like to change of Authorisation to that VLAN, sure the example guide provides the steps.
 It is possible do it on EWC on C9115AXi?  - check the cisco document and compatibility matrix.
BB
I cannot find the right answer, if does or doesn't support with this model (C9115AX). So, I put one this discussion room my doubts.
Thank you
Are you not able to view my Image posted and EWC supported that model?
BB
Yes.
Thanks.
I can see, but the main question is vlan assigned by RADIUS.
On Policy Profile, section Access Policies if I specifies the vlan, the laptop get IP, and have connectivity (nice!). But if I do not  specifies the vlan, the laptop stay connect on the wifi, but have no connectivity, because didn't received the vlan assigned by the RADIUS.
What I need to configure in order to received de vlan assigned by RADIUS?
António
PS the configuration is an attachment
Your config misses two eventual parts:
  1. The VLANs need to be added to the Flex-Profile
  2. The policy profile needs an "aaa-override"
Hi Karsten Iwen,
Can you provide an example for both misses config?
 native-vlan-id 1076
 vlan-name IoT
  vlan-id 1162
 vlan-name USER
  vlan-id 1032
 vlan-name GUEST
  vlan-id 1161
 aaa-override
Thank you Karsten Iwen.
