EWC (C9120) questions
Dominic Stalder
Dear community
I am somewhere, that internet access is limited and I try to setup a small WiFi for a hospital. I wanted to use a C9120 as EWC + AP and some Aironet 1832 as APs.
I converted the C9120 to EWC 17.3.6 but as soon as the EWC boots up, the L3 connection is lost. I am not able to access the EWC w/o serial console.
1. somewhere I read, that an active internet connection is needed, to setup the EWC, is that true? I don‘t think so.
2. Can I somehow upgrade the EWC (offline) to another version?
Thanks in advance
dominic
Hi M.
I was finally able to get it to work with EWC 17.9.4 and configure the ip address statically configured:
interface GigabitEthernet0
mac-address 0000.1111.2222
ip address 192.168.1.10 255.255.255.0
no negotiation auto
Thanks for the help anyway.
Dominic
10 Replies 10
Mark Elsen
 - You don't need an active internet connection for the EWC . Concerning upgrading , what do you mean by an offline upgrade ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi M
thanks for the confirmation, that no internet access is needed. Then it is a specific problem of 17.3.6, that the EWC is not able to connect to the network.
I want to try another EWC version, but because I have no L3 access to the EWC, I am not able to up-/downgrade it via TFTP or something similar.
Dominic
                   >... Then it is a specific problem of 17.3.6, that the EWC is not able to connect to the network.
 - Negative this does never happen, provided correct network parameters such as address and netmask are provided during first installation. Now if we talk about out of the box installation(s) , look at
             https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
                                             In that case the EWC can get an (initial)  address trough DHCP (too)  ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Dominic Stalder
I can confirm, that it IS a problem; the EWC gets an IP address from DHCP server (192.168.1.1) but it can not reach it:
WLC#show ip int brief
GigabitEthernet0 192.168.1.14 YES DHCP up up
WLC#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
  - Where are you trying to reach it from ? Is the particular device on the same subnet as the EWC AP ? If not do you have a routable-path to the EWC AP (subnet) ? If it is remote  , are there any firewalling or remote access restrictions ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Very simple setup: I have a switch with a mgmt IP address in VLAN 1 and a client also in VLAN 1 on the same layer 2 domain.
I can ping:
client > switch mgmt
switch > client
But I can never ping the EWC from the client or the switch and I can never ping from the EWC to the client or the switch.
- What address is the client using ? Is the EWC and the client in the same
VLAN ?
M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi M.
no negotiation auto
Dominic
- Good work !
M.
       Beauty and terror
      Just keep going
       No feeling is final
Rich R
Glad to hear you got it working - good choice to upgrade - 17.3 is almost end of life.
For future always check the TAC recommended releases - link below.
