Export mac filter from wlan controller
robertquinn
Community Member
I've seen a discussion about importing mac addresses into the mac filter db on a cisco controller but is there a way to export the mac filter db?  I have a Cisco 5508.  Thanks.
Robert Quinn
Scott Fella
Have you tried show run-config commands or perform a backup and open the backup in notepad.
-Scott
5 Replies 5
Scott Fella
-Scott
Didn't think of that but it got me there: "show macfilter summary"
Thanks!
Is there any way to export this list, see the format, and then import a new list of MAC addresses and devices to the Wireless Controller?
I have ran the "show macfilter summary"  and it displays all the results, however I need to export and remove all devices in the list...then import a list of new devices (+-500).
Is there any way to do this with an import file?
You can export configuration from WLC to another includes macfilter list.
Thank you!
adrian.silva
Community Member
Another faster option would be:
show access-list permit or show access-list deny
Regards.
