Factory reset 1602I Autonomous mode.
Have a 1602I AP in Autonomous mode. (ap1g2-k9w7-tar.153-3.JF15.tar)
How do I erase/delete to factory reset?
23 Replies 23
The write erase is the first method to try.  The next method is to go to the flash and delete the private files, nvram, etc.  Here are my notes from a long long long time ago:)
Console/SSH/Telnet to the AP:
debug lwapp console cli < for lwapp
debug capwap console cli < for capwap
erase /all nvram
undebug all
reload
Example:
Entered the username and password
erase /all nvram:
[confirm]
undebug all
reload
[confirm]
Hold reset for over 30 seconds to get to ROMMON
ap:delete flash:private-config
ap:delete flash:private-multiple-fs
ap:boot
-Scott
@Scott FellaIs my AP lwapp or capwap when running as
Autonomous ??
BR
Look at the bottom of my notes under rommon.  That is for any ap type.
-Scott
debug lwapp
debug capwap
Both not an option
Have "(debug uap) Universal AP debug commands" instead.
Do I need to use that?
BR
Rich R
I thought we had already concluded you have faulty hardware?
What are you hoping to achieve through further debugging?
If you really want further help from people here then capture the full console log from your AP console port to a TEXT file (not a screenshot, not a PDF) saved as <filename of your choice>.txt showing EVERYTHING from the AP console from the moment you turn on the power with every command you type and every response the AP gives.  Attach that text file to your reply here as a file attachment.  You are drip feeding tiny titbits of information making a complete view and accurate diagnosis impossible.
Regarding your debug commands - lwapp and capwap (lwapp pre-dates capwap) only apply to a lightweight (controller based) AP (k9w8 IOS).  You stated that your AP is running autonomous (k9w7) IOS so those are not valid options on an autonomous AP.  Scott already replied to your previous reply saying "Look at the bottom of my notes under rommon".
@All helpers
The solution for me was:
ap#delete flash:config.txt
ap#delete flash:config.txt.bak
ap#reload
Thanks all for trying to help.
BR
OFH
Glad you able to fix the issue, even you can reset to factory should wipe all the config as we suggested before.
any way all good...
BB
Have tryed that, but didn't work (don't know why)
Not that model you mentioned, but yes for higher models of AP.
BB
