Finalizing my SSL cert for my guest WLAN
Sean Coogle
I have a guest network on my 10 controllers. These are Cisco 5508's with 7.6.100 code. I had a trusted cert through entrust to bypass the security warning when on the guest network. This has expired as of 3 days ago. I had this renewed and sent back to me by our security team. I got a link to entrust to create the chain of certs and made one in notepad, but I am missing something. I think it is the SSL piece that I am confused on. Does anyone have experience with what I have shown below? After this is complete, I can FTP this onto my controllers like I did a year ago.
Sean
Stephen Rodriguez
you want to download and install OpenSSL .98a to do that portion. And yes once that is complete you can then TFTP that to your WLC
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/70584-csr-wlc-00.html
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Carlos Leiton
Hi Sean,
This is the deal, with version 7.6 you need to make sure the certificate chain is complete. Otherwise you will have problems loading the certificate into the WLC.
Basically you need to follow the steps mentioned on this guide:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
I think you should be right now doing the steps on the second section: Obtain the Final.pem File
It is very important to follow these steps one by one, I have done this process hundreds of times and if you follow the steps it will work.
Make sure you paste the device certificate, the intermediate or intermediates (if there is more than 1) followed by the root certificate.
Also you need to have the private key on a separate .pem file
Once you have these files (an all-certs.pem, and a key.pem) then you followed the process of combining using the OpenSSL guidelines.
Note that only OpenSSLv0.98 will work, any flavour of 0.98 will make it.
The one I prefer to use I download it from this link:
https://slproweb.com/products/Win32OpenSSL.html
I have tested with Win32 OpenSSL v0.9.8ze Light and it works fine
Note as well, the password you use when doing the final.pem, is the same password that you use to upload the file to the WLC.
In my experience, most of the time this process could fail because the intermediate and root certificates does not match or does not complete the full chain. For the same CA there could be several different intermediates or root CA, so be careful to use the appropriates for your device certificate.
