Firmware Upgrade
russell-r
Level 3
Level 3
all-
when upgrading the firmware to my 350 ap, will the config remain the same or will i need to reconfigure the AP? my intent is to do this remotely via the web browser..... the current is 11.05 and my plan is to upgrade to 12.0T.
thanks
russell-r
Level 3
Level 3
thanks all - i've completed the upgrade w/ no issues.... it keeps the prior configuration...
Whenever you upgrade the image version, the config will remain the same as earlier. As its backword compitible.
