Flashing and Moving Red Light in AP
mahesh18
Level 6
Level 6
I converted the AP into Lightweight and currently it is not connected to any WLC.
Need to know if flashing red lights which are moving from status,ethernet icons are due to the fact that AP is not connected to any WLC?
Also need to confirm that lightweight AP have no config mode like autonomous ap?
MAhesh
2 Accepted Solutions
Rasika Nayanajith
What is the AP model. Depend on AP  model, sometime these indicators mean different thing. Refer table 1 of the blelow link
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/2700/quick/guide/ap2700getstart.pdf
Yes,there is no config mode in LightWeight, as everything is managed by WLC and you do not want to configure anything on AP itself.
Only thing AP require is to know where is the WLC to go and register. There are multiple options (DHCP option 43, DNS, etc) . Refer below for more details.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
In case you would like to statically configure controller information see below link
http://mrncciew.com/2013/03/17/ap-registration/
Rasika
Hi Mahesh,
Here is the LED status indicator for 1252 AP
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1250/installation/guide/1250HIG_TD-Book-Wrapper/125h_c3.html#wp1111349
Message type
Ethernet LED
Radio LED
Status LED
Meaning
Boot loader status
Green
Amber
Off
DRAM test in progress.
Green
Green
Green
DRAM memory test ok.
Off
Red
Off
Board initialization in progress.
Off
Blinking green
Blinking green
Initialize Flash file system.
Off
Green
Green
Flash memory test ok.
Amber
Off
White
Initialize Ethernet.
Green
Off
Blinking blue
Ethernet test ok.
Green
Green
Blinking green
Starting Cisco IOS.
Off
Off
Off
Initialization ok.
Association status
Green
Normal operating condition, but no wireless client devices are associated with the unit.
Blue
Normal operating condition, at least one wireless client device is associated with the unit.
Operating status
Green
Ethernet link is operational.
Blinking green
Transmitting or receiving Ethernet packets.
Blinking green
Transmitting or receiving radio packets.
Blinking blue
Software upgrade in progress.
Blinking green
Blinking green
Blinking green
Access point location command.
Boot loader warnings
Off
Off
Blinking red
Ethernet link not operational.
Red
Off
Red
Ethernet failure.
Amber
Off
Blinking blue
Configuration recovery in progress
(Mode button pressed for 2 to 3 seconds).
Off
Red
Red
Image recovery
(Mode button pressed for 20 to 30 seconds).
Blinking green
Blinking red
Blinking pink
Image recovery in progress and Mode button is released.
Boot loader errors
Red
Red
Red
DRAM memory test failure.
Off
Red
Blinking red and blue
Flash file system failure.
Off
Amber
Alternating red and green
Environment variable (ENVAR) failure.
Amber
Off
Rapid blinking red
Bad MAC address.
Red
Off
Blinking red and off
Ethernet failure during image recovery.
Amber
Amber
Boot environment error.
Red
Amber
No Cisco IOS image file.
Amber
Amber
Boot failure.
Cisco IOS errors
Blinking amber
Transmit or receive Ethernet errors.
Blinking amber
Maximum retries or buffer full occurred on the radio.
Red
Red
Off
Software failure; try disconnecting and reconnecting unit power.
Cycle through blue, green, red, and off
General warning, insufficient inline power (see the "Low Power Condition on Autonomous Access Points" section).
Rasika
*** Pls rate all useful responses ***
5 Replies 5
Rasika Nayanajith
Rasika
AP is 1252AG-k9
Hi Mahesh,
Message type
Ethernet LED
Radio LED
Status LED
Meaning
Boot loader status
Green
Amber
Off
Green
Green
Green
Off
Red
Off
Off
Blinking green
Blinking green
Off
Green
Green
Amber
Off
White
Green
Off
Blinking blue
Ethernet test ok.
Green
Green
Blinking green
Starting Cisco IOS.
Off
Off
Off
Initialization ok.
Association status
Green
Blue
Operating status
Green
Blinking green
Blinking green
Blinking blue
Blinking green
Blinking green
Blinking green
Off
Off
Blinking red
Red
Off
Red
Ethernet failure.
Amber
Off
Blinking blue
Off
Red
Red
Image recovery
Blinking green
Blinking red
Blinking pink
Boot loader errors
Red
Red
Red
Off
Red
Off
Amber
Amber
Off
Rapid blinking red
Bad MAC address.
Red
Off
Amber
Amber
Red
Amber
Amber
Amber
Boot failure.
Cisco IOS errors
Blinking amber
Blinking amber
Red
Red
Off
Rasika
Many thanks Rasika
I have a CISCO AIR-CAP1720I-E-K9 device.
I tried configuring the device, I connected the power using a AC/DC 50-60Hz power adapter. I have this network cable plugged in and see Red, Amber and green cycling. After a while the device blinks to red. It seems to receive IP from the router and PING seems to send replies but doesn't open with web interface or any. Kindly help some one.
