10-07-2015 12:16 AM - edited 07-05-2021 04:03 AM
Dear Sirs
I have some problem with VWLC(8.1.111.0) configuration in Flex+Bridge Mode by two LAP1262N APs and I have not found any proper configuration guide. There is a stable connection between Root And Mesh APs. On root side there is no problem and clients obtain IP Addresses and they work but on Mesh side clients are authenticated and associated to the VWLC but they cannot obtain IP address. My last configuration is detailed below, I would be thankful if you could help me with the solution.
AP1(ROOT):
Mode: Flex+Bridge
AP Role: RootAP
Bridge Group Name: Test
Backhaul Interface: Ethernet
Bridge Data Rate (Mbps): Auto
Ethernet Link Status: UP
Install mapping on radio backhaul: Enabled
VLAN Support: Enabled
FlexConnect Group Name: Test (With Associated VLANs)
AP2(MESH):
Mode: Flex+Bridge
AP Role: MeshAP
Preferred Parent: (Root Base Radio MAC address+first hex digit changed to f)
Backhaul Interface: 802.11a/n
Ethernet Link Status: Down
Install mapping on radio backhaul: Disabled
Inheritance Level: AP-Specific
Best Regards
10-09-2015 02:56 PM
Are the AP specific VLAN mappings of the MAP the same as the ones configured in the Flexconnect group on the RAP? If your test client is associated to the MAP, do you see it's MAC address being learned on the switch port connected to RAP? If so, in which VLAN?
If you also want to use the 5Ghz (backhaul) radio on the MAP for client connectivity, you need to check that box on the flexconnect tab of the MAP access-points as well.
Please rate useful posts... :-)
10-14-2015 06:55 AM
Dear Freek Terpstra
Thank you so much for your useful answer, I did some other tests but I faced another problem with VLAN overriding(Dynamic VLANs), these are some steps of my job:
1- I checked Install mapping on radio backhaul option in the MAP AP, but nothing was working again, the mac address was not seen on the switch port but the client was authenticated on VWLC. This is the Flex connect configuration of AP and as you can see there are some configuration restrictions on AP-Specific Inheritance Level.
2- Then I did some WLAN-AP VLAN Mapping configuration on flex-connect group and I checked Override VLAN On AP for changing MAP Inheritance Level to Group-Specific.
3- After that change I considered that MAP AP supported VLAN and the Client obtained IP Address but Dynamic VLAN(Radius VLAN Overriding) was not working and after client’s Authentication the ip address was obtained from that static VLAN, and again everything specially VLAN Overriding was working correctly on RAP AP with the same flex-connect group!!!
After all I would be thankful if you could offer any solution for this case or if you have tested the same scenario successfully please guide me with the correct steps (or maybe the VWLC has some problem with this kind of configuration).
Best Regards
03-30-2017 01:11 PM
I have a similar problem, but with 1532 APs, 8510 WLC and an 8.2.121 image.
Try to take the vWLC and the APs to 8.0.140 image. For me, this resolved the problem, at least temporary. I think it is a bug. I tried to find it on bug search tool, but with no luck.
Finally, I think I will have to open a case, because I cannot stay on that image because of the new wave 2 APs that I have to bring into the network.
