flex-connect split Tunneling design
ammarkazmi
Visitor
I have configured a remote AP to be worked in Flex-Connect mode, I have created split-tunnel ACL to be applied to Flex AP. in Flex-AP-Group to the specific WLAN i need to test it on. but its not working.
WLC model is 5520 with ios 8.5.135.0
AP model is 3802i. (but later i confirmed it from cisco document that 3800/2800 doesn't support flex-connect split tunneling feature.
then what i did was i tried to test it on 3502 AP. but still unable to get the desired result...
any help would be appreciated.
i don't know if i am missing something.
Design rough diagram is attached just to make things clear that how everything is connected
Note: everything is working fine on local mode.
we have WLC installed at a central location and AP's from diff sites reaching WLC to join it and to serve clients normally
but we have one site where the users are supposed the access the servers that are installed on their local site and we don't want to tunnel back that traffic to WLC. we want all the traffic to be centrally switched except the one subnet(server's subnet).
sorry for my drawing! i have used "paint".
Rasika Nayanajith
Haven't tested it on recent codes, but here is one of my post about that feature. See you follow same flow
https://mrncciew.com/2013/09/09/split-tunneling-with-flexconnect/
Rasika
*** Pls rate all useful responses ***
Hi Rasika!
i followed your blog, step by step, what makes me confused is AP<==>switch-port configuration.
tried to google it but didn't find any help..(only in case of split-tunneling, not local switching).
from the mentioned link
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/ch7_HREA.pdf
"The Split Tunneling solution assumes that the subnet/VLAN associated with a client in the central site
is not present in the local site (that is, traffic for clients that receive an IP address from the subnet present
on the central site will not be able to switch locally)."
the point and then its explanation in " ( ) " contradicts, i mean first they said that subnet shouldn't be present on local site and then they said that that subnet if existed centrally would be unable to locally switch(split-tunneling).
"The Split Tunneling functionality is designed to switch traffic locally for subnets that belong to the local
site in order to avoid WAN bandwidth consumption. Traffic that matches the FlexConnect ACL rules are
switched locally, and NAT operation is performed changing the client’s source IP address to the
FlexConnect AP’s interface IP address that is route-able at the local site/network."
regarding this point it looks like we have to keep the Ap/Switch port as access. as, it stated that traffic will be sourced from AP's ip when split-tunnel ACL entry for local switch subnet will be matched and AP is connected with the access port on it's management vlan. so, is that mean we don't want to change it to trunk(port of switch on which AP is connected).
these points are confusing .
if you can help me with this.
i even tried to work with TAC but they are confusing it with local switching where we have to enable " flex connect local switching" option under specific WLAN. i don't know why but may be this feature is rarely used by the customers..
Thanks and Regards.
Pls post below output from your AP to understand current configuration bit better.
AP#show derived-config
Rasika
