Flexconnect access points issue after WLC upgradation
Hey guys
We upgraded the WLC 8500 from 8.0.110.9 to 8.4.100.0 & after upgradation most of the flexconnect mode access point(AIR-CAP3602I-N-K9) unable to join the WLC.but local mode access point successfully joined
Can anyone suggest why access point unable to join the WLC.
6 Replies 6
Scott Pickles
Level 4
Level 4
That's a pretty big code jump.  Did you check to see that your AP models are still supported on the new code train?
I checked AIR-CAP3602I-N-K9 model support in new code train.
Rafael E
The issue is too general. More information is needed to understand what can be causing this problem:
  • Are AP able to reach WLC?
  • If one of the affected AP are change to local mode, will it fix the problem?
  • Are the AP in Flex, located in a remote office? Is the connection good enough for the AP? if so, based on what?
  • AP logs?
  • WLC AP join statistics?
Rafael
Saludos,
Rafael - TAC
Hello Rafael,
When we checked from AP console we are unable to reach WLC,but when we checked with laptop connected to the switch we are able to ping WLC.
After removing the VLAN and reconfiguring the switches fixed the problem
Yes located in remote office,working fine till the upgradation.
Looking for your support...
Srikanth
Hello Srikanth,
"When you said unable to reach WLC".
  • Did the AP had an IP Address?
  • If yes:
    • Can AP reach its GW?
by reading the workaround sound to me more a wired issue rather than AP in FlexConnect.
Rafael
Saludos,
Rafael - TAC
I guess, in software versions 8.0 is stable next to that 8.3.x is stable. so try by degrading to 8.3 version. So your problem might be solved.
