Flexconnect Authen Using ISE
tppatrick1
Level 2
Level 2
Hi All,
Do we need any special configurations on ISE and Flexconnect SSID to authenticate with username and password? We are using C9800-CL
Any help or support is appreciated.
9 Replies 9
Thank you so much @MHM Cisco World
You are so welcome friend
MHM
Mark Elsen
 - In essence not , meaning the authentication schemes will not vary on Flexconnect ; you can always have a review of the intended C9800-CL configuration with the CLI command show tech wireless and feed the output into Wireless Config Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thank you
ammahend
Your Network Access Device (NAD) will be AP subnet if the authentication is no set to central and it will be Controller mgmt IP if your authentication is central (which most people would do), policy logic will remain same more or less, you can read more here
-hope this helps-
Thank you, @ammahend. I will go through the guide and feedback.
Rich R
> ISE to authenticate with username and password
Presume by that you mean web auth - for that you should refer to:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213920-central-web-authentication-cwa-on-cata.html and
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_vewlc_central_web_authentication.html
As Marce said flex local or central switching doesn't make much difference but it will need to be central authentication.
If you're referring to 802.1x then it can be done as flex local authentication whereby the AP sends the radius directly to the ISE for authentication independently of the WLC.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213921-flexconnect-configuration-with-central-a.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thank you @Rich R I will use the links provided.
