Flexconnect split tunneling in 8.0
patrick.kofler
Hi all,
Perhaps someone here can help me further. I'm trying to configure split tunneling on the wireless controller which is running code 8.0.110.0.
I've followed the config guide. I created the Flexconnect ACL, defined the interesting and bound it to the Flexconnect group. However the interesting traffic is not locally switched. When I tried to do it on a WLC running 7.6.130.0 it is working perfectly.
Did I miss a new parameter, which needs to be defined?
Patrick
6 Replies 6
patrick.kofler
After TAC has been involved it was confirmed to be a bug.
Would like to see bug ID information if you have
Rasika
Hi Rasika,
The bug is CSCut91036. However the workaround stated does not work, as I have tried reconnecting the client multiple times.
Patrick
Hi Patrick
Did you find a solution to this. I seem to have the same issue with a teleworker solution. As I understand it this is a new bug in 8.x Would using 7.6 solve it?
Regards Rasmus Sindum
Hi Rasmus,
It is working on 7.6. It's beyond me why Cisco decided to terminate this bug as the workaround clearly does not work.
Patrick
To bad
I'm using a new 5520 controller. No 7.6 software for me.
I might have to run a TAC case on this.
Thanks for following up
