Flexconnect standalone mode EAP-FASTv2
m.abdulmajeed
Frequent Visitor
Frequent Visitor
Hi All,
I'm aware that the network access device is irrelevant to the EAP methods used as it encapsulated in RADIUS. We intend to deploy a wireless setup where APs in the branch should be able to authenticate users in the event of a WAN failure using the local ISE PSN. The APs are configured in flexconnect mode and in the normal operational scenario would be doing local switching, central authentication. In a WAN failure scenario the expectation is for it to perform local switching, local authentication in standalone mode.
For authentication we intend to use EAP-FASTv2 with EAP-chaining. Would like to know if anyone has encountered any limitations in this type of configuration.
Aadhil
Shivu b
Level 3
Level 3
Before implement check whether do you have certificate in ISE.
Please rate if this post helpful for you
