Foreign-Anchor Failover
fatalXerror
Level 7
Level 7
Hi Guys,
Some clarifications because I have a foreign-anchor controller in each of my 2x sites.
1. If my primary site foreign controller goes down, I expect that it will failover to the foreign controller in my secondary site. Will my primary site anchor controller creates a tunnel to the secondary site foreign controller? Or,
2. Will my secondary foreign controller use the secondary anchor controller regardless if the primary site anchor controller is still running?
Thank you.
Mark Elsen
  - Check these info's : https://community.cisco.com/t5/wireless/failover-in-between-two-anchor-controllers-in-two-different-data/td-p/2626833
                                    https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/configuring_auto_anchor_mobility.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi @Mark Elsen , are these still applicable for the newer controllers?
 - Review this document for supported topologies :
                  https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213913-building-mobility-tunnels-on-catalyst-98.html
 M.
