Getting a BR1310 to connect to a WLC
Colin Higgins
Level 2
Level 2
I have a very old WLC (4402) that I inherited at a client site. One of the access-points that connects to this WLC had to be wiped and re-installed, and since it is not a LWAPP, I am a bit unsure as how to get this to connect to the WLC
The AP required a static IP and hostname, which has been configured. I also regenerated the cert.
What do I need to do to get this thing to communicate with the WLC?
Scott Fella
That bridge doesn’t connect to a controller. That has a different OS in which you need to manually configure.
-Scott
There are other APs of the same type connected to the controller. They have static IPs assigned
 - I have some doubts , but then anyway your 'definitive guide' to AP-model and controller-compatibility :
            https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
M.
