Guest access for vendors/clients
rileymartin
I have a single AP setup using PEAP with MS Win2k3 IAS/RADIUS. I would like outside vendors and clients to be able to come in and be able to access the Internet as well as a printer. I believe in order to authenticate with PEAP the laptop must be a member of the domain which we can't do with vendors and clients. I'm new to wireless so I'm lost as how to set this up. If anyone is familiar with how to do this I would really appreciate some direction. Thanks in advance.
Riley
15 Replies 15
If you want to stick with 802.1x can you not use MD5 or TLS instead of ms-chap-v2??
Using the first two will not require the user to be on the domain. This works for wired so im sure it will work for wireless.
