01-02-2010 09:24 AM - edited 07-03-2021 06:23 PM
I have scheduled a guest account on WCS (6.0), valid 180 days, generate password every day and email to myself, and applied to our WLCs( 5.1). The first day, guest account was created on all WLCs, and emailed me the password, worked fine, the second day, I received email with the new password, but the guest account has disappered from all WLCs, on WCS, this guest account still show as 'Active' but not apply to any WLC.
Thanks in advance for your help!
01-05-2010 04:18 PM
What is the exact version of 5.1 and 6.0.x are you running for both WLC and WCS ? Try the following settings "Choose Administration > Background Tasks, then click Guest Accounts Sync" to access this page. And try disabling this feature and see if that makes any differences.
-nael
01-07-2010 02:55 PM
01-08-2010 09:02 AM
Our WLC version is 5.1.151.0 and WCS version was 6.0.132.0 but I just upgraded it to 6.0.170.0. Guest Account Sync option is enabled now ( once a day). I think I find something, one is the time on WCS and WLCs was different before (corrected this now), second, the guest account start time and end time was set to same time (1:00 Jan 1, 2010- 1:00 Jul 1, 2010) or from 8:30 Jan 1, 2010 to 8:00 Jul 1, 2010. I thought this time setting is the lifetime of the account, but actually it's the active time of the account on every scheduled day, so I change this to from 1:00 Jan 1, 2010 to 23:00 Jul 1, 2010, So far,it works fine - this guest account is created at 1:00 and removed at 23:00 everyday.
By the way, is there any documentation to tell how WCS works with WlC underneath the GUI?
Thanks for your help!
01-08-2010 02:36 PM
WCS works with the WLC using SNMP.
You can enable debug snmp all enable on the WLC and see the activity.
Also on the WCS server you can install wireshark and take a packet capture, that will show you the snmp packets.
There is no documentation for this.
